sprocket rubber O rings
Discussion in 'Maintenance' started by bandit_287, Dec 2, 2012.
  1. bandit_287
    bandit_287 Active Member
    Chain rubber O rings
    Had a nice shiny gold DID chain fitted a year or so ago and I've just been out to clean the bike and chain with chain cleaner and lubed it back up, but I notice that a couple of the O rings have split and are popping out from the links. It's only about 3 or 4 bits of rubber appearing along the chain at various stages. Is this acceptable or is the chain faulty?
    #1 bandit_287, Dec 2, 2012
  2. megawatt
    megawatt Well-Known Member
    No it ain't acceptable! One split O ring can ruin your chain. Either replace the damaged area with new links and two rivet links or buy a new chain?
  3. bandit_287
    Just looked at the invoice and it was fitted in June 2011 so no chance of a replacement from Bikespeed. Bit disappointed though as I've only done about 4000miles with it on. I'll leave it until the spring and get a new one as the bike won't be doing much until then.
  4. megawatt
    How did you look after it?
  5. bandit_287
    Cleaned about every 400 miles with chain/brake cleaner, then lots of silkolene chain lube anti-fling stuff that seems to get flung everywhere lol.
    #5 bandit_287, Dec 2, 2012
  6. bandit_287
    ...and sometimes WD40 to clean it too.
  7. megawatt
    When you say you cleaned it with chain/brake cleaner, how did you apply it and clean it off?
  8. bandit_287
    Sprayed the cleaner onto a rag and gave it a good scrub until clean.
  9. Haggler ®™
    Haggler ®™ Active Member
    B rake cleaner!!!!..............that,ll make the rubber rings go stiff! and then break away.
  10. bandit_287
    I thought brake cleaner was just a simple de-greaser just like all the other products on the market?
  11. Haggler ®™
    It,s like Paint Thinners!
  12. bandit_287
    Oh really! That'll be why the O rings have dried up then. We live and learn.
  13. Haggler ®™
    If you were to put an O ring in a puddle of Brake Cleaner it would most often 1.Expand 2.Disapear 3.Go brittle 4 Nothing as its a neaoprean O ring.I,m sure some would disagre but I use O rings all the time and often come accross seals attacted by Brake cleaner.Depends I suppose what material the O ring is made from...........I just NEVER use brake cleaner near my chain.
  14. bandit_287
    I'm surprised that it's so aggresive. I've used it to strip and clean brake parts that have rubber end caps and clean up piston seals on calipers which I guess are made of the same material? I'll be more careful with it from now on then and stick to cleaning the chain with good old WD40 and chain cleaner.
  15. megawatt
    Can't say that I've had any problems with brake cleaner either mate. I use Comma brake cleaner and buy 12 tins at a time. I clean crud off my chain with paraffin and give it a final wipe with brake cleaner on a terry towel until chain is dry and clean. Then I spray it with MucOff dry ptfe lube. Managed over 25,000 miles outta my last DID X ring Gold chain ?
    Is there anything else that you have used that may have damaged the O rings?
    #15 megawatt, Dec 2, 2012
  16. phantom
    phantom Active Member
    is it the older muc-off chain and brake cleaner...now called degreaser that you were using
    because thats what I always use with no ill effects.
  17. bandit_287
  18. megawatt
    Anyway, the old chain sounds knackered, so buy a top quality DID X ring Gold, be very careful when rivetting the new link on and look after it with the correct cleaner and lube. I lube every 200 miles and clean about every 1000miles or every month. Main thing is don't use a stiff brush to apply the cleaner, use a soft, paint brush if you have to. 4000 miles is terrible for an O ring or X ring chain and the most important parts are the rings!!!
  19. bandit_287
  20. megawatt
    Good luck mate, make sure that rivet link goes on properly with the correct grease between the X rings.
