Afraid not but does look better. I guess the press included the weight saving of the rear seat foot pegs
I did the subframe and used 2 x Racebolt drilled ti nuts and 5 x MVS hollow ti bolts. The Carbomoto carbon undertray and number plate bracket is lighter than the DPM item.
Bang on .... Not a great deal but if your going all the way then it all mounts up! I think it's around 23 Ti bolts I fitted including the main fixing bolts in total! Now when you remove all the stock bolts and stick them in a bag it's a surprise how much weight you have!!
Swapping them for for Ti has saved between 2-3 kilos for me. If I uses more aluminium for non stressed bolts it would have been much more
Sounds about right Simon.... I've even removed my rear seat lock! And used some lock-wire attached to the sprung loaded catch... Hard core
You'd be surprised but he average human dump is not that much, however I do find some people are full of more shit than others No matter how fat you may be once you ride light weight bikes nothing else comes close..
