Stator Reseal
Discussion in 'Maintenance' started by Gatsoburner, Nov 10, 2021.
  1. Gatsoburner
    Gatsoburner Active Member
    Just a few pictures of the inside of the left engine case.
    I had a small oil leak which having done the repair may have been down to a previous owner having cause to open up the case and not seal it proper after.
    I was wondering what is find on opening having read various forums on what I may encounter.
    The bolts came undone really easy which made me think too easy ?..
    A tap with a wooden mallet and the case cover pulled away relatively easy.
    As you can see there was a tiny amount of bonding with no gasket. This cleaned up easily enough and a very lite rubbing down cleaned up the metal.
    I've then used a gasket plus a thin layer of bond.
    The amount of oil summed up to a thimble full at most which wiped away easily.
    The slight burnt coils, 3 on the ends causes no concern, touch wood I've had no issue with power through the electrics.
    Refit, tighten and I've left it to dry til tomorrow.
    As I say, just some pics which may help another member
