Sticking brakes !!!??
Discussion in 'Maintenance' started by Jandy, Jan 24, 2016.
  1. Jandy
    Jandy Active Member
    If this as been asked before I apologise in advance
    The problem is everytime I go to the bike it's so stiff to move around as though the front brake is almost on its like pushing the car around the garage, this happens the day after a ride or the day after a good wash, is there something you can put on the brakes to prevent this or something to clean the disc with ???????
  2. sps170373
    I would check the Pistons as sounds like there not retracting properly and causing the brakes to bind
  3. slasherr
    slasherr Active Member
    Also check the pins aren't corroded or worn
