When I pull in the clutch from time to time, essentially when it's up to temperature their is a slight stick, a bit like a seal braking, it's only slight but very annoying. It's bin like this from new so I thought it was because it was new, however it's still the same after 700 miles? Has anyone experienced this issue, will it improve or is it a warranty issue?
Is it like a knot in the cable getting stuck, if so more than likely the slipper clutch and totally normal, mine does the same.
I had a issue like this 2 months ago. it was as if the clutch cable was not fully releasing properly as the bite point had changed and when i gave it a handfull the clutch was slipping slightly. looking back it does sound right that the slipper clutch wasnt working properly. it has never done it since so fingers crossed
