Stuck in gear .
Discussion in 'General 1000RR Discussion' started by Barney1, Apr 20, 2013.
  1. Barney1
    Barney1 Guest
    Hi, today I went for a ride out with lee and Eddie ,
    Going down a straight at about 60ish and coming to
    a roundabout , drop down the gears 6,5,4,3 stuck...?
    The gear would not drop too 2nd , pushed bike to side
    of road and where the gear indicator is it has a small line
    showing like a (dash,not number ) then gears went down to 2nd ,1st
    and to neutral , lee played with the clutch adjuster
    and off we went got to Crossgates and same thing happened
    again ,so far touch wood it not happen since
    Any ideas has to what this could be thank you
    Ps any technical stuff ask lee not me p:D.....
  2. Garyb
    Garyb Moderator.
    Did the actual gear box physically change down Barney and it was only the gear indicator showing this?
  3. Barney1
    Barney1 Guest
    Sorry mate , the gears would not change down , just stuck in 3rd ,
  4. Garyb
    Garyb Moderator.
    Bloody strange that mate, hope you get it sorted :)
  5. Andrew
    Andrew Active Member
    Arthur's your man for this one me thinks!
  6. phantom
    phantom Active Member
    Do you let the clutch out between down shifts or
    Are you trying more than two downshifts at once?
    If trying more than two then its normal.if its getting
    Stuck just goung into second I would look at clutch
    Or selector fork problems.
    #6 phantom, Apr 20, 2013
  7. martinowen
    Get it looked at mate as if I had gone another few feet when I had my gearbox issue it would of locked up on me and I wasn't hanging around! I think I would of been doing a pretty good superman impression over the handle bars
  8. Barney1
    Barney1 Guest
    When I changed down I let clutch out mate 6,5,4,3 stuck , gear lever would not go down anymore ,
    Got on side , pressed lever down would not move , but went up the box , went to 4th , then dropped
    back down to normal , gear indicator showed number but then just a dash , did this twice ,?
    But not on the ride home .
  9. derick
    derick Active Member
    I had this on my old 125 which was due to a bent gear selector. It went up the gears fine but wouldn't go down more than 1 or 2 using a normal technique. If I touched the underside of the lever with my boot (not enough to change up a gear) I could then get it do go down again. Looking at it it was as though the lever wasn't returning back to the correct position when I was pushing down on it. Annoying but rideable as long as you remembered.
  10. phantom
    I would get that checked out, could be something gone wrong in the
    clutch, gear return spring or worst case a selector fork.
  11. Kevin1
    Kevin1 Elite Member
    Thing is. Once it has done it once you'll never fully trust it again. I had a Honda CR-V that had a completely flat battery for no apparent reason, it wouldn't even open unlock the car with the fob. It let us down and missed an appointment, after that we were never had full confidence in it. It's gone now, and been replaced with a happy smiling Civic.
