Stuck while trying to remove rear footpegs. help needed
Discussion in 'Maintenance' started by restone, Oct 30, 2013.
  1. restone
    restone Active Member
    Got as far as almost getting battery tray / under fairing off. However its still attatched down beneath fuel tank. Got to get tank out of the way any way.
    Do I need to disconnect wiring harness/ loom and battery.........are there any hidden attatchments.
  2. Repsol Rob
    Repsol Rob Elite Member
    Look up Normanstanleys posts he has detailed numbered pics within his posts.........
    but there are loads of previous info on this..........
  3. Repsol Rob
    #3 Repsol Rob, Oct 30, 2013
  4. just_me _and _me _bike
  5. Repsol Rob
  6. restone
    Well thats a piece of piss ain't it.:rolleyes:
    Think I'll pull the engine out while I'm in there:p might as well its about all thats left on the bike.
    Still thanks folks and ........might be in the shed for a while!!!!!
  7. wedgiewolves#223
    wedgiewolves#223 God Like
    I found it really easy ..... But I'm stripping them everyday but take your time rear cowl seat I just lifted tank and then unbolted subframe split in half leave battery tray just hanging down for some street hooks so you put your pegs on and off easily
  8. just_me _and _me _bike
    Bloody show off :p ^^^
  9. wedgiewolves#223
    Just take your time put bolts removed back in holes to
    You come to re assemble . Get pissed off take a break you will get there
  10. wedgiewolves#223
    Ha ha always here if anyone needs any help if close enough
  11. speedy11673
    speedy11673 New Member
    I managed to do mine without lifting tank or taking battery tray out because the subframe splits you can take one side of at a time I found this easyer
  12. restone
    Job done folks pretty easy really. The split the subframe method is way easier as long as you've got a torque wrench you do have to be carefull of the thin paint though.
    Had to take tank off because I wanted to get into air box to fit K&N race filter. Managed both and fitted my new arrow titanium race can to race headers. Its very very sexy!
    Took about 2 hrs for all 3 jobs.
    PC5 comes tommorow then its 3,2,1 blast off:D
    Many thanks again.
    1000rr.co.uk 'making mechanics out of monkeys since 2004'
