Subframe fitment
Discussion in 'Mods, Upgrades, Accessories and Products' started by tuktuk, Nov 7, 2018.
  1. tuktuk
    tuktuk Elite Member
    Are the subframes the same throughout 08-16? ABS different?
  2. Boothman
    Boothman Elite Member
  3. tuktuk
    tuktuk Elite Member
    Cheers. Can you swap a subframe from an abs bike to a non abs if you keep the original battery tray?
  4. Boothman
    Don’t know to be honest, but the ABS one is a lot deeper looking at the manual than the none abs version.
  5. tuktuk
    tuktuk Elite Member
    A few places seem to advertise as 08 to 16 but other list 08 to 11 and 12 to 16 o_O
  6. Boothman
    I think that’s a question for a dealer or someone with access to their microfiche to compare actual part numbers
  7. TheMickster
    TheMickster Active Member
    Hi mate
    Don't quote me :) but I think the metal side rails are the same part number (if they are the same colour).
    Have a look on Fowlers website under the parts bit.
    The ABS has a different plastic battery tray so I imagine you can just swap the trays over.
  8. vic_ster51
    vic_ster51 Active Member
    The Subframe itself the same through 08-16 no difference at all. The abs battery tray is different to non abs. Also 1 of the brackets different as rectifier bolts to that on abs models. But still fits fine.
    The abs tray sits alot lower etc.
    So if you getting a subframe from a abs bike, fitting it to a non abs bike is perfectly fine. Just use your non abs plastic tray and bolt on and go
  9. PauloHRC
    PauloHRC God Like
    As @vic_ster51 says.......subframe is exactly the same, only the battery/under tray is different.
  10. tuktuk
    tuktuk Elite Member
    Thanks guys, appreciated as always.
  11. tuktuk
    tuktuk Elite Member
    So I think I was concerned over nothing anyways as didn't SP bikes start from 2012?
    Never thought I'd be doing this job again but hopefully having a couple of extra holes which no one will take a second look at will be worth the pain :D
  12. vic_ster51
    SP were 2014. There subframe fits you just can’t mount rear pegs and or the brackets that replace them
  13. tuktuk
    tuktuk Elite Member
    Perfect :)
