Superbike front brake kit
Discussion in 'Parts, Accessories & Clothing' started by gaz22, Nov 18, 2018.
  1. gaz22
    gaz22 Active Member
    Not sure if anybody with track bikes on here but i’ve Just listed a full PFM brake kit on eBay including master cylinder, narrow track discs and six pot calipers, will fit 08 blade onwards
    The full kit with master cylinder would cost over £2200 I would take £750 for the lot
    Calipers could do with new pads, sbs do a full front set for around £50
    Gives loads more power and feel than standard kit or standard calipers with brembo master
    I used this kit on my track bike for 12 months and it was 1 finger braking all the time even when hot
    Doesn’t have to be just track bike if someone is looking to bling up their road bike but bear in mind the disc are ductile iron and will show rust if left wet, this will clean up as soon as you use them but they do really need to be kept hot to make them work at their best
    Links below
    https://www.ebay.co.uk/itm/382636038267?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    https://www.ebay.co.uk/itm/382636057174?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
  2. jokeshopbeard
    jokeshopbeard Active Member
    God that's sexy.
  3. TheMickster
    TheMickster Active Member
    Hi
    Do you still have to use the caliper spacers with these?
    Cheers
    Mike
  4. gaz22
    gaz22 Active Member
    Mike
    Sent you pm reply but no I didn't use any spacers on mine, they were bolted to the standard fork leg bottoms
    Gaz
