Hi all, Hope someone can help, this is for a friend with a 2010 blade.. Problem is; on the motorway, constant throttle at around 70mph, the bike will start surging, like the fule is being cut off for a split second then coming back!? Mods: Pcv O2 eliminator Running a base map for his setup He's tried putting in fresh petrol, same problem! Any ideas?
Sounds more like an intermittent misfire to me, try load the engine up in a high gear ie just off labouring the engine, and see if does it then.
Does it for about 3-5 seconds! :-/ thinking it may be running a little lean, but want more peoples opinions! Thanks
