Suspension set up comparisons
Discussion in 'General 1000RR Discussion' started by LowSide76, May 15, 2022.
  1. LowSide76
    LowSide76 Active Member
    Hi Guys,
    Just wondered what other peoples suspension set ups are for comparisons.
    I had mine set up at ohlins suspension place near me.
    They set mine to
    Fp 11 from full soft
    Fc 2.5 turns out from hard
    Fr 1 turn
    Rp 7/10
    Rc1.5 turns out from hard
    Rr1.5 turns out from hard.
    Front and rear rider sag was 36mm with me at 15st without gear .
    Since then i have tweaked it.
    Fp 12
    Fc 2
    Fr 1.5
    Rp 8/10
    Rc 1.5
    Rr 1 1/4
  2. Coda
    Coda Active Member
    You have a standard '15 bike, with stock Showa BPF forks?
  3. LowSide76
    Yea mate completely standard 2015 blade with the showa bpf and the balance free shock
  4. Kake
    Kake Active Member
    Put 40mm front sag and 35mm rear
  5. Coda
    Coda Active Member
    I haven’t played much with my suspension (2014 std non-sp), left it at standard for the road but added a couple of clicks preload front and back when I took it on the track. I will have a think about your settings and maybe try them out.
    I’m just under 14st without gear.
  6. Patriotk11
    Patriotk11 New Member
    I was going to say I think weight would play a factor lol
  7. Kake
    Kake Active Member
    Having said that, once you've gotten that rider sag correct you need to check free sag. In the shock free sag should be 5 - 15 mm and in the forks 5 mm more. If you don't get those free sag numbers you need to replace the springs. 5mm or less you need heavier spring in the shock and the same thing goes for forks. How much you weigh in kg's and what kinda riding you want the suspension to work for you ?
