Suspension Settings
Discussion in 'General 1000RR Discussion' started by alex peacock, Sep 16, 2015.
  1. alex peacock
    alex peacock New Member
    Hi, just wondered if anyone has suspension settings as a base for around about a 12 stone rider. Yes I realise they can vary on loads of thing but would be handy to have some as a base :)
  2. danthorrr4
    danthorrr4 Active Member
    If you could let everyone know what year of Blade you have then someone will have settings. I put something up for a 2004 cbr1000rr and sulaco on here gave me a benchmark which has worked out well on the road. I have put the settings sulaco suggested below.
    04/05
    FRONT SUSPENSION:
    Spring preload-Adjust the preload adjuster on the fork leg with a 22mm spanner by turning it counter clockwise until it lightly seats.Thereafter,turn it clockwise 7 turns.
    Rebound damping- Turn the screw adjuster clockwise until it lightly seats,then turn it counter clockwise 2 turns. 2.5 for 06/07
    Compression damping- Turn the small screw adjuster on the bottom of the fork leg clockwise until it lightly seats,then turn it counter clockwise approx. 2 turns until the punch mark aligns.
    REAR SUSPENSION.
    Rebound damping- turn the screw adjuster on the bottom of the shock clockwise until it lightly seats.Then turn it counter clockwise approx.2 1/2 turns until the punch marks align.
    Compression damping- turn the screw adjuster on the remote reservoir clockwise until it lightly seats,then turn it counter clockwise about 9 clicks so that the punch marks align.
    Spring preload- The spring preload adjuster is in the standard position in position 4 of the 10 on the collar.
  3. alex peacock
    the year would help :) its an 09 thanks
  4. danthorrr4
    Cant help you with the 09. I'm sure someone will.
  5. sulaco
    sulaco Active Member
  6. RRoss
    RRoss Active Member
    Factory settings shouldn't be too far off for someone weighing 12st. It's us (slightly)heavier guys that need a bit more tweeking:D
  7. Shutty
    Shutty Well-Known Member
    If it's done a bit of miles and never had the fork oil changed, I would do that, totally transformed my bike, but I did get suspension set as well, but I'm 14st
