Suspension upgrade
Discussion in 'Mods, Upgrades, Accessories and Products' started by gsco, Jan 5, 2012.
  1. gsco
    gsco Active Member
    Hi guys looking at maybe dropping my forks out my 09 plate and getting them sorted out by the guys at K-tech. I know the work these guys do is the dogs but just dont know whether, I would see any advantage from it, mainly quick road and track day now and again. I reckon would be £400 for the work to be carried out or is the standard suspension up to the job ......................:cool:
  2. CastrolCraig
    CastrolCraig Active Member
    Ktec 20ssk piston kit, springs to match your weight & matched oil, job done.
  3. Benn The Pig
    I'm having Ktech front springs and service, and rear spring swapped to for my weight roll in roll out service £400 both ends!
  4. CastrolCraig
    Difference is though i beleive he is talking about a piston kit upgrade also whereas your only having springs & oil.
  5. Benn The Pig
    Oh I see
  6. Smiler
    Smiler Active Member
    Just an old fart so just had new springs fitted to match my weight and new oil........
  7. PeterT
    PeterT Active Member
    I have had my front swapped with k-tec springs and 5 weight oil and it transformed the bike, not sure if the benefits of a piston kit will change it untill i get a better shock for the rear this year. looking to get a nitron race unit .
  8. exfire
    exfire Elite Member
    Got mine booked in for February at MCT, they totally transformed my 954. I was going for the KTec piston kit, as recommended by CC. Money is a little tight so just going for match weighted new springs and oil and set up. Plus they are going to fit my recently acquired Ohlins rear shock complete with piggyback adjuster........I can't wait. Plus of course a set up. Will see how it handles then, if not enough then the Ktec piston kit will have to be done.
  9. gsco
    gsco Active Member
    Yeah Craig thats exactly what im thinking off, is the difference real noticeable........................................
  10. gixerlc
    gixerlc Active Member
    k-tech can also do an effective mod to the rear shock to ill report back once Ive had it done :) 130+ the vat then a spring is bout 80 i think
