Swingarm sliders
Discussion in 'Mods, Upgrades, Accessories and Products' started by flatstickHRC, Jul 28, 2011.
  1. flatstickHRC
    flatstickHRC Active Member
    Anyone know if there are swingarm sliders 08-
    The type which go thru the axle
    R&g don't have any listed but they do fork ones.
    I've seen puig do them but can't find any online for sale.
  2. dazza
    dazza Active Member
  3. flatstickHRC
  4. dan.1moore1
    Had front and back evotech axle sliders on my last bike . Good quality . Never tested them out thou , thank god lol
  5. flatstickHRC
    Cheers might try them
    Maybe the r&g ones for 07 bikes work as the evotech ones list all years as same part number.Ndont list them for 08 on the web site though
  6. dan.1moore1
    Possibly .. Im sure iv seen R&G ones on a bike here or maybe .net . Give R&G a bell tomorrow. Seem a bit strange for them not to make 1 for 08+
  7. dan.1moore1
  8. flatstickHRC
    To use on a paddock stand inthink you have to take the bobbins out of them and fit in the swingarm lugs each time which is a bit of a pain.
  9. dan.1moore1
    Yeah that sounds a bit daft
  10. flatstickHRC
    Had a look and they only need moving if you remove the rear wheel as to get the wheel out the alloy spacers/mounts have to come out.
  11. JM1
    JM1 Active Member
    I'm using GB Racing ones, but they fit to the swingarm lugs.
  12. flatstickHRC
    Ok cheers
    Not keen on using the lugs as a crash protection point
    Going to give them evotech ones a go I reckon
  13. flatstickHRC
    Just bought them evotech ones. They look pretty good and hopefully work well
    £67 delivered. Hopefully never need to test them out.
  14. Freedom of choice
    I am thinking of getting these from R&G to match the crash bobbins and front fork protectors. Can anyone tell me how easy they are to fit, given that I am quite a numpty with a new tool kit.
  15. dan.1moore1
    Peace of cake mate . undo the spindle nut , pull the spindle , swap your blocks for the R&G's and refit and tighten
  16. Freedom of choice
    Thanks Dan, I was thinking that I might have to remove/drop the rear wheel and then make all sorts of fiddly adjustments afterwards. Will the rear wheel stay put without any chain adjustment either. Wish they did the blocks in silver to match my swinging arm but sure it will stilll looks sweet and protect it in the event of a spill.
    While I have your attention, I think it might have been you last year that recommended I change the grips to the soft (grey) ones to reduce the annoying tingle and dead right hand syndrome. Are they also easy to fit as well, ie put glue on, slide on, job done?.
    Having read a few back threads maybe R&G bar ends might also help as they seem quite a bit heaver than the OE.
    Thank you Dan.
  17. dan.1moore1
    The Wheel will drop when you pull the spindle out but with the chain on it won't go far . Just put a block of wood under the tyre so it stays put and inline .
    If the new blocks are the same dimensions as the OE ones then it may just be tighten and ride but check the chain to be sure .
    Yeah grips are no problem to change . I always use Renthal soft grips which are really tight fitting but so soft you just stretch them over the bars and they are solid with out using any glue at all ,
    the hardest part is getting the Originals off .
  18. Freedom of choice
    Thank you Dan
    Will order some over the next few weeks.
  19. dan.1moore1
    Take plenty of pics of them going on mate .. i look forward to seeing them fitted
  20. Freedom of choice
    Oh my gawld, Renthal soft grips in short or long ? Questions Questions. Think I better stay in my comfort zone of legal sales contacts, they are so much simpler.
