Symptoms of charging problems
Discussion in 'General 1000RR Discussion' started by morpheus20170, Mar 20, 2014.
  1. morpheus20170
    morpheus20170 Active Member
    When I bought my 06 Blade I had charging problems which I knew nothing about until I had problems last year.
    My symptoms were the feeling of a flutter in the engine especially under 4k revs and the feeling that the throttle response wasn't as good which I am led to believe is due to the power required to run the ECU and the injectors.
    I do not understand why the 06 stator has issues even after I have gone to the newer type MOSFET Regulator/Rectifier as my understanding is that the clearance between stator and rotor has been increased and the magnets have been reduced in strength on the 06/07 from the problems that the 04/05 models have.
    Unfortunately I feel that my charging issues are back. The battery is less than a year old (Honda item) and my stator was rewound by West Country Windings (Not sure how long their warranty is, 6 months I think).
    Can anyone please advise me of the symptoms you experienced and what I can do now.
    Best wishes
    Paul
  2. Haggler ®™
    Haggler ®™ Active Member
    Got any oil leaks aswell?. Have you done a charging test?
  3. morpheus20170
    Can see any oil leaks. What charging test mate? Got a multimeter but not sure how to use it properly tbh
  4. rodders4legs
    rodders4legs New Member
    Select dc on the multi meter
    (Solid line with a broken line underneath)
    Go across the battery with ignition off should have around 12v
    Then start the bike and go back across it should read 13.5 to 14.5v
    If it's not then you have a charging issue, poss reg rec there a common honda fault
  5. morpheus20170
    Thanks very much mate. I had 12.87v with bike off. 14.1 at 5k revs with high beam on but it doesn't feel right esp low down
  6. rodders4legs
    Na it should be around 14v at tick over
  7. morpheus20170
    I just did what Haynes manual said mate but 14.1 seemed quite low
