Hi, just fitted a Evotech tail tidy, the one with the three supports, and i know a few of you have these as well so two things. 1) does it move slightly once you have done all the bolts up and 2) what did you do with the wires!! I've got them as tight as i can but they don't look great and just wondered what you have all done, did anyone cut the connectors off as they don't reach inside the tail unit?
I have just fitted one two my new. Repsol! I soldered an extension to the indicator and number plate light and joined them under the seat, then I used the section of cable cover from under the seat and used it from the tail tidy to under the seat, if that makes sense? It looks good!
