taking this mess back to Honda :(
Discussion in 'General 1000RR Discussion' started by lexathon, Feb 14, 2016.
  1. lexathon
    lexathon Active Member
    yucky fork leak...
    Been meaning to get it done since about day 7, but a little moisture has recently turned into a flood. I guess you get what you get when they spend 60 minutes assembling the bike.
    Hopefully I can ride it over to Honda tomorrow without slipping on my own juices!
  2. sps170373
    That's not good! How long you had it?
  3. lexathon
    Since September.
    Don't expect too much of an argument!
  4. Slimwilly
    Slimwilly Member
    If no other owners have had problems then you just got a bad un, and it will be sorted,,fingers crossed for you
    • Old Old x 1
  5. Cbrjay
    Cbrjay Well-Known Member
    i had a few issue with my blade a year late and
    some one bought brand new and had a problem, think they ended up with new forks
  6. scooby
    scooby Elite Member
    could just be a bit of grit unde the fork seal,a quick run around with a thin bit of plastic,and spray of brake cleaner soon sorts it,if it is in fact that.
  7. derchef
    derchef Well-Known Member
    little stone chip ,fork leg is fucked ,oil is out
  8. Slick
    Slick Elite Member
    I've been really unlucky with forks, on average I get a leak every 15k or so. If it not the seals then it's the bushings, last time it was the stanchions, the amount I've spent maintaining and upgrading the OEM forks could have gone towards a pair of Swedish gold:mad:.
    Still I've got a set of K-tech upgraded OEMs that are sublime;)!
    Make sure they give you a set of new pads too, did a track day on contaminated pads ( with fork oil) and lets say I had to replace not only my leathers jeans but also my seat cover too!!
  9. Ian E
    Ian E Active Member
    Its probably worth taking the cable tie off before you take it in - just in case they say that could have caused it. I bought a second hand bike which had a slight fork leak and a cable tie had been fitted very tightly to the fork leg. A mate suggested I remove the tie and it was fine from then on! Maybe just coincidence as I know a lot of people fit them to check suspension travel.
  10. Slick
    Slick Elite Member
    incidentally how much should you have left?, I have around 10mm and that after some serious high braking and stoppies/endos
  11. lexathon
    Good point - will do.
  12. lexathon
    Well top notch service from Chiswick Honda. Bike is back - shiny and clean. Lent me an nc750 for the day.
    Fork seal replaced and all put back together again - noticeably a happier ride (obviously!) and bike looks like new again! :)
  13. Slick
    Slick Elite Member
    fecking snap, leaking seal again.
    Booked into local to have it replaced but managed to stop the leak by scaping the seal with an old credit card. It's lost bit of oil, should I get the fork serviced anyway - the forks have done about 15k since last change
  14. sinewave
    15K since the last service?
    Most definitely then! :)
  15. Slick
    Slick Elite Member
    Thought as much, seem to be throwing money at these forks, would have easily covered some ohlins cartidges or a couple sets of BPFs
  16. sinewave
    PM Yorkshire Gooner
    BPF's can come in surprisingly cheaply! ;)
  17. Slick
    Slick Elite Member
    I hear you SW!, for some reason I feel committed with these forks as they are K-tech'ed up just for me! Seen YG sells SP ohlins for about grand fricken bargain if I hadn't spanked that (and some )already on my OEMs:oops:
    Already thinking heathen thoughts and moving on to something new maybe a kwak, yam or even german!
