Tank stickers
Discussion in 'General 1000RR Discussion' started by wurzel, Feb 13, 2013.
  1. wurzel
    wurzel Active Member
    It must be on here somewhere but can i hell find it. Removing stickers from the tank cover. Do i heat them up with a hairdryer first and then peel them off.
    Thanks
  2. Garyb
    Garyb Moderator.
    Yep. Hair dryer mate. Move it over the whole surface of the sticker. Nice and easy, and a little tlc if it leaves any residue glue about.
  3. Si.
    What the esteemed gentleman said mate. Any glue left, remove with wd40.
  4. Remal
    I use heat or sticky label remover
  5. ShinySideUp
    ShinySideUp Elite Member
    What they all said! :D
  6. Benn The Pig
    Yeah don't focus the hear to much it'll melt, heat it slowly testing the sticker often to see if it'll peel off
  7. wurzel
    Thanks all. Going to garage now hairdryer in hand.
  8. Givover
    Once you have removed the sticker try lighter fluid to get off the remaining glue
  9. Barney1
    Barney1 Guest
    Or petrol if its a repsol :D
