Tech Q Can Anyone Help
Discussion in 'Lounge' started by Lozzy, Nov 17, 2015.
  1. Lozzy
    Since installing a recent update on my Hudl I've ended up with a ? mark over the wifi symbol on the left and an ! mark over the wifi on the right as per the pic. The only way I can now link into wifi like today at Costa is by clicking the old O2 wifi tab at the top! I was getting a message that said something about a portal!?!
    I've Googled the problem but don't understand the answers probably because I'm an imbecile when it comes to IT :(
    Can anyone help me sort it pls in step by step simples instructions
  2. exuptoy
    exuptoy Elite Member
    You probably just have to set the wifi protocols up again.
    Probably just a security update to the wifi settings I would have thought. I don't own a Hudl so can't be more specific.
    Try deleting the wifi connection and re-establishing it.
  3. Barstewardsquad
    The exclamation mark means it can't talk to the interporn over the WiFi. If it's your home WiFi try deleting and re-adding the connection.
    If you are on a WiFi connection in somewhere like Costa or McDs you have to go to a page first. Try going to google and see what it does. The WiFi should intercept it and give you a login page if it wants you to log in etc.
    Failing that I may be at a loose end at the start of Dec and can meet you at Barlborough, Gainsborough or somewhere and have a look for you.
  4. t0m541
    t0m541 Senior Member
    That's what happens when you leave the kitchen !!!! :p
  5. Lozzy
    :p :D
  6. ShinySideUp
    ShinySideUp Elite Member
    In my best Chris O'dowd accent from IT crowd.......Have you tried switching it off and back on again??? :D
  7. ShinySideUp
    Android lollipop added a new symbol icon for the wifi logo here's the description.
    Exclamation mark on the Wi-Fi symbol
    If your phone’s running Android 5.0 Lollipop, you might see this new symbol. It shows that your phone’s using the new Smart Network Switching feature to give you the best possible internet connection. If you connect to a Wi-Fi network that’s not working, Smart Network Switching will automatically put your phone back on the mobile network so you get a stable internet connection.
    Don't have a clue about the ? In top left corner tho, is the hudl a cellular and wifi tablet or just wifi?
    What happens if you swipe down over the '?'
    #7 ShinySideUp, Nov 20, 2015
  8. Lozzy
    Yep turned it off n on several times & no joy. It's wifi only.
    I've tried exuptoys suggestion but until I get to a wifi spot on my travels tomorrow I won't know if it's worked!
    The update also changed my keyboard & I hate the new one :(
