Tech Spec Tank Pads
Discussion in 'General 1000RR Discussion' started by Swiss T, May 30, 2012.
  1. Swiss T
    Swiss T Active Member
    I recently bought a set of the Tech Spec tank pads; I can't remember the exact name but they are the more discrete type (the least textured).
    They havn't met with my expectation so I have now bought stompgrip carpet runner jobbies.
    It turns out the Tech Spec are resusable & can be removed & reapplied at will.
    Does anyone want to try them?
    It will cost you about £3 in postage & if you like them, you could make a small donation to charity; they cost me thirty odd quids (I think).
  2. phantomx0_1
    phantomx0_1 Active Member
    How much!?
  3. phantomx0_1
    I've PM you
  4. Only1Matrixxx
    Only1Matrixxx Active Member
    The least textured is High Fusion...
    I have had Snake Skin on my CBR600 which I found was good, and now I put the new material C3 on the Blade, and they are perfect!! Soft, grippy, and don't hurt when riding without Leather trousers...
  5. Swiss T
    Replied matey. Just need your address. :)
  6. WyreFlyer
    WyreFlyer Member
    Looks like you have an HRC like me, how does the black look on it, I can't imagine it on mine? Can you post a picture?
    Thanks WF
  7. phantomx0_1
    I've replied did you get it?
  8. 1000rr73
    1000rr73 Active Member
    Hey Swiss, can I ask why they didn't live up to your expectations please? Also, how easy were they to remove? Cheers
  9. Swiss T
    They didn't provide me with the grip level I want; but they are the least grippy material so it's my bad.
    They peeled off very easy when I removed them.
  10. Only1Matrixxx
    Here you go!!
  11. Only1Matrixxx
    Here you go!!
    I placed mine with a small gap at the front of them, trying to keep a little bit of the red stripe on the tank... Not bothered either way, placement was the most important thing...
  12. WyreFlyer
    WyreFlyer Member
    Thanks for those pics, they look much better than i imagined. I'll have to give them a try, no grip at all when I wear my dragin jeans.
    Cheers WF
