Temprature
Discussion in 'Maintenance' started by Mike07, Aug 20, 2013.
  1. Mike07
    Mike07 Active Member
    Hi, I've just got the Blade '2007'. Can anyone tell me the general parameters for the coolant temperature, in normal road work. Mine seems to vary from 80C to 105C, Is this typical. ........ Thanks in advance, Mike.
    PS... The other question I should have asked, what temp does the fan kick in?
    #1 Mike07, Aug 20, 2013
  2. RRoss
    RRoss Active Member
    Seems normal,I got the 2012 and it sits about 80 on open roads and up to about 104 stuck in town.
  3. Kentblade
    Kentblade God Like
    Spot on when I had my RR6
  4. martinowen
    Yep all normal
  5. GappySmeg
    GappySmeg Well-Known Member
    Pretty similar to my RR7. Thermostat opens at about 80, fan kicks in at 103.
  6. BoroRich
    BoroRich Elite Member
    Yeah seems about normal. Mine generally sits at around 80 - 85 until I get stuck in traffic and then it goes up into the 90s and then over 100 where the fan kicks in.
  7. Mike07
    Well Thanks for the very quick help chaps, I have just tested mine on tick-over in the garage 83c Stat opened, 96c fan initiated. I would say these figures correlate pretty well with your findings so I'm happy with the cooling side of things.
    Thanks,
    Mike.
