Hi I have the rr6 now every now and then the the thermostat light comes now if I turn the bike off then back on it doesnt come back on, any ideas as I'm scratching my head a bit
The light should only come on as part of the dash sweep / check then go off , i think only when the temp is at around 120 it should warn you ,,, try disconnecting the battery then reconnecting to see if it reboots it,,,, or it could be dirty connector at the sender . They would be the first things I would do
