threadlock
Discussion in 'General 1000RR Discussion' started by keithg1748, May 27, 2020.
  1. keithg1748
    keithg1748 Active Member
    any ideas on how to clean threadlock off bolts and the bolt hole before putting news bolts in ? thanks.
  2. Barstewardsquad
    They sell threadlock cleaner, or you could use a tap and die if feeling brave.
  3. keithg1748
    I didn't realise they sold a cleaner , I will have a look , but im not brave enough to use a tap and die , lol , cheers.
  4. Boothman
    Boothman Elite Member
    Acetone (nail varnishes remover) will for most but you obviously need to be careful for plastics/painted surfaces. Try it on the bolts first and if that works okay then earbud it inside the tapped holes
    • Dislike Dislike x 1
  5. bonjo
    bonjo Active Member
    I use a brush either plastic or brass depending on the situation. Then white spirit followed by brake cleaner if necessary
