Throttle cable routing
Discussion in 'General 1000RR Discussion' started by maxxuk, Mar 14, 2014.
  1. maxxuk
    maxxuk New Member
    Good evening ladies and gents!
    Does anyone know whether the throttle cables on a 2006 blade are routed LEFT or RIGHT of the top yoke centre?
    I am removing my Renthal bar (this is a single handle bar, not slip-ons) and riser reverting her back to original so I can fit the Repsol kit on (the previous owner had to butcher the fairing to accommodate...hey-ho).
    Got all the fairing bits off, removed Renthal bar and riser, got the original handles on and now find the throttle cables bind as soon as I slip the throttle grip fully on- it does not do it if left more than half off the bar. The way i found the throttle cables routed they are passing the yoke centre nut on the right side- presume they would need to go to the left so to reduce the slack and stop the throttle from binding once the grip is fully on? :confused:
    Sorry if I am answering my own question, it's just been a major ball ache so far and I don;t want to take it all apart again more than once....so please if anyone knows, tell me so I can keep my last bit of sanity! :D
    Thanks a bunch in advance!
  2. maxxuk
    maxxuk New Member
    I have worked out that I could leave the throttle cables routed the way I found them i.e. running past the right side of the yoke centre nut. I just needed to adjust the cable angle at the throttle grip itself to address the binding issue.
    I still don't know if this is the factory setup, but it works for me- hope this will be useful info for someone else!
