Tip Sensor??
Discussion in 'Maintenance' started by stevekk, Feb 3, 2014.
  1. stevekk
    stevekk Active Member
    Hi folks,
    I was wondering, is it possible that a tip sensor from a different bike or from different years might be compatible with an rr7 blade. I've to replace mine(I think, will know for definite once parts start getting delivered) and can only find a couple on ebay for the rr7 but quiet a few for the 600rr and some look very similar.
    Thanks all :D
  2. graemewalker
    graemewalker Elite Member
    Can't see why it won't work,if wire connectors ars the same,just make sure when you put it on make sure the arrow is pointing upwards and not in the down position.
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    It's just a 3 wire setup I put a rr7 1000 on my mates rr3 cbr600rr I had to chop plug off as different and just soldered wires
  4. sinewave
    All the sensor circuit board is looking for is a certain degree angle from true vertical and may be a time delay before killing the ignition.
    Any should work in theory although diff Manufacturers may programe diff lean angles and time delays into their pcb's/ECU's
  5. stevekk
    Thanks guys, will look into it, starting to get bike back together now finally, sorry took so long to reply folks, cheers
