Hi guys. I've just bought a black top yoke (genuine Honda) as I thought it'd look much better than my silver one on an almost entirely black bike. So basically I need to swap them over. I think it's a 41mm socket I'll need (obviously a torque wrench) is the ignition barrel held in with anything special or is it just an Allen head? Just so I know before doing it tomorrow
Yes the ignition barrel is held in by some sort of security bolts (shear bolts now I remember) 2 from the underside. You might get away with using a torx bit if you are lucky.
