Torque settings for axle bolt?
Discussion in 'General 1000RR Discussion' started by Si., May 6, 2012.
  1. Si.
    Anyone know what it is?
    Cheers!
  2. lee711
    lee711 Active Member
    rear axel nut 113Nm ..
  3. broos3
    broos3 Active Member
    rear axle 113nm
    front axle 79nm
    front pinch bolts 22nm
  4. Si.
    Cheers guys!
  5. Jamiestrada
    Can I add to this what size is the socket to fit the rear axle bolt as I don't have one big enough and need to buy one :)
  6. stevebetts
    stevebetts Well-Known Member
    Its 32mm Bud.
  7. Jamiestrada
    Thanks Steve :)
  8. megawatt
    megawatt Well-Known Member
    Just tighten it till you fart mate. You won't snap it unless you are a heavy handed gorilla !!!
