Torque settings
Discussion in 'Maintenance' started by kingy3, Sep 2, 2019.
  1. kingy3
    kingy3 Active Member
    Hi guys does anyone know the torque settings for front and rear sprockets on a 2010 blade cheers
  2. Spygoat
    Spygoat Well-Known Member
    Found this quick reference online:
    Pinch bolts - 16 ft.lb
    front axle - 58 ft.lb
    front caliper bolts - 33 ft.lb
    front rotor bolts - 14 ft.lb
    Steering stem nut - 76 ft.lb
    The front wheel spacer with the rim goes on the brake side
    upper and lower triple clamp bolts - 17 ft.lb
    OE clipon bolt - 20ft.lb
    rear axle - 83 ft.lb
    rear rotor bolts - 31 ft.lb
    rear sprocket bolts - 47 ft.lb
    Front sprocket - 40 ft.lb
    Rear shock + link bolts - 33 ft.lb
    The rear wheel spacer with the rim goes on the sprocket side
    Throttle adjust lock nut. - 4 ft.lb
    Passenger foot peg - 20 ft.lb
    OE rearsets - 27 ft.lb
    Oil drain bolt - 22 ft.lb
    Oil filter -20 ft.lb
    clutch lever mount clamp bolt - 9 ft.lb
    clutch banjo - 25 ft.lb
    Frame slider/engine bolts, (fr + mid hanger bolt) - 47 ft.lb
  3. kingy3
    Thanks mate
