Torque wrench
Discussion in 'Maintenance' started by just_me _and _me _bike, Oct 15, 2013.
  1. just_me _and _me _bike
    Can anyone recommend atorque wrench please, ive got around £125 to spend on one, so after sum recommendations on what you guys may have used n liked.
    Gonna b usedfor tightening the chain mainly n sum other not soo demandung jobs.
    Many thanks everyone
  2. Scott
    Scott Active Member
    Wow u got lots to spend. I got I sealey one that's good
  3. sinewave
    What Torque range do you require?
    Screwfix are doing KILLER Deals on Teng Tools Torque Wrenches at the mo (Teng gear is Top Notch!)
    Torque Wrench - Search Results | Screwfix.com
    I've bough the 1/4, 3/8 and 1/2" versions, BARGAIN! :cool:
  4. ahmedf
    ahmedf Active Member
    I've got the halfords 8-60Nm and 60-300Nm.
    Can't fault them and covered by lifetime warranty.
    Find someone with a trade card and you should be able to get them for much cheaper as they seem to have put the prices up recently.
  5. wedgiewolves#223
    wedgiewolves#223 God Like
  6. sinewave
    There's always one whose gota go one better aint there Wedge! :rolleyes:
  7. just_me _and _me _bike
    Lurvely, how much if u dont mind me asking and what size would i need for tightening up the nut in rear wheel, or do they come with different size errrr nuts?? U can tell im not mechanically minded right?? :p
  8. PeterT
    PeterT Active Member
    Torque wrenches are only as good as the person using it and not how good the tool is, and really any version from the good old humble spring variety will suffice given the wide range that manufacturers give in torqueing up given values of various bolts. When I was building engines values were given for varying temperatures of the bolts and what greases and lubricants used. Arp bolts give several different values for bolts with and without their special assembly lubes. So unless you are building a Hart 420R to spec then you should consider a wrench that fits your budget and the bolts that you are tightening up, it's not like you are using one time stretch bolts made from Ti alloy costing £45 a throw!!!
  9. wedgiewolves#223
    This does 5.5nm - 145nm rear nut on blade is around 113nm and front 78nm caliper bolts 45nm 103nm steering stem but so does the lot . I p/x my old torque wrench this was 299.99 they gave me £150 for my old one so good deal I thought . Only reason I upgraded the click wasn't loud enough in a crowded paddock this vibrates and a loud beep .
  10. wedgiewolves#223
    I wondered when you would give me grief buddy
  11. just_me _and _me _bike
    Cheers for the info guys, that snap on looks lurvely bit of kit, wedgie n im sure ur the envy of the paddock, but dont think i cud justify it to the Mrs as we r moving house this w.end aswell.
    Ill pop into screwfix n check out them Teng Tools.
  12. wedgiewolves#223
    It is a bit overkill but I don't just use it on my bike and it's gotta match my box lol ImageUploadedByTapatalk1381870102.900499.jpg
  13. Mike07
    Mike07 Active Member
    With that budget you may think of getting two. One for lower and one for higher torque ranges. Perhaps a 1/4'' and a 1/2'' drive. Teng are very good.
  14. just_me _and _me _bike
    Chers Mike, its mainly gonna be used to toghten me chain, so am i right in saying the 1/2" drive will suffice?? i got a 2012 Blade and im not mechanically minded at all, adjusting chain is a big job for me! :(
  15. Jonnymac
    Jonnymac Active Member
    Norbar or Halfords professional. I think Norbar make the Halfords one, but i'm not 100% on that.
    Teng are OK too and of course snap-on are good, but very expensive. Britool could be a possibility too.
    Don't buy a second hand one as you cannot be sure on it's calibration
    For me the best bang for buck are the Halfords professional. I use all of their tools and can recommend them very highly (must be the professional range though)
  16. PeterT
    Halfords gear is good quality, you cannot go wrong with their tools in the professional range.
  17. wedgiewolves#223
    3/8 with a adapter to 1/2 inch will be fine for the bigger rear wheel sprocket I think it's 32mm 22mm front then you ain't got a massive 1/2 wrench lying around
  18. sinewave
  19. martinowen
    So the HRC is secretly powered by the repsol then wedgie.
    See even HRC owners need some repsol in their lives ;)
  20. Jonnymac
    Wedgie!!!!!
    We'll never hear the end of it now lol
