TPS Possible issue
Discussion in 'General 1000RR Discussion' started by Darren lee, Nov 5, 2018.
  1. Darren lee
    Darren lee New Member
    Appreciate if anyone can help with some advice, just had a track bike I've converted go on the dyno today and its going into limp mode at high RPM, its a 2005 model with less than 40mins from brand new.
    Its been sitting since 2005 with no use , I,ve just got it form a mate.
    The Dyno guy is a mate aswell and recons its an issue with the TPS, just been looking and seen you cannot get just a new TPS but secondhand throttle boddies complete are going for around £75.00.
    Its seems a shame to remove brand new throttle boddies to replace with secondhand over whats a possible TPS sensor issue.
    Does anyone know if I can source just a TPS, possibly an aftermarket one or anyone have one I could buy secondhand or new that they know is good.
    Cheers
    Daz
  2. exuptoy
    exuptoy Elite Member
    Make sure someone hasn’t swapped the TPS and MAP sensor around. On the 08 bike both plugs are blue and are close to each other. When I fitted my Bazzaz to my RR9 I used the wrong one and my TPS signal was bouncing around like fuck on the dyno. Turns out I’d fucked up with the blue plug!
