Track/race seat unit
Discussion in 'Mods, Upgrades, Accessories and Products' started by raphael, Aug 6, 2019.
  1. raphael
    raphael Elite Member
    I want to put a full race seat unit on my bike this winter but don’t really know what parts I need?
    I will be keeping the bike as a road bike aswell so will need to keep/put a rear light. If possible? Does this just go over the original subframe or do I need something different?
    Any tips/advice would be much appreciated
    Cheers
  2. Spygoat
    Spygoat Well-Known Member
    Not sure on the blade, but on my GSXR track bike, it was a new subframe and battery box. No accommodation for a tail light on the unit I have.
  3. TheMickster
    TheMickster Active Member
    You will prob need a seat plate with the mounts built in if you use the standard subframe as you won't be able to use the standard seat if its a full race tail section. not sure if you can get ones that you can use the standard seat with.
    you'd then have to check it clears the standard subframe ok and prob cut out a hole for the rear light, as the standard light mounts to the subframe. I've got a race tail section in the garage so I'll see if it goes over the standard subframe ok if you like as I'm swapping my fairings this weekend. you'd then have to sort a mount for the number plate and indicators etc, or go with an integrated tail light. If you go with a race subframe you have to sort a different solution for rear light etc.
  4. raphael
    Thanks for the detailed response mate, much appreciated.
    that would be very helpful if you could let me know
    Cheers
  5. sps170373
    There are race tails which allow you to keep the standard seat and use original subframe, but you’d need a different tail light for running and stop plus indicators, similar to the led strips I run
  6. sps170373
  7. TheMickster
    Hi mate, I tried the couple I’ve got and you can get them to fit on standard subframe, but might need a bit of tweaking to look good, you have to remove the under tray piece and lock mechanism.
    The 2011 looks like it would fit with a seat plate, but looked a bit naff where it meets the tank, no idea what make it is as it came as a spare with my bike.
    3284F31B-C49D-4B58-B3B5-20D82F3B7381.jpeg B3D89579-2979-40E8-816C-2EB951DBD133.jpeg F4CFA9D5-6B57-49D1-9A3A-CB4D34A640B5.jpeg 404A7797-E81C-4477-9A86-E405C781107E.jpeg
  8. TheMickster
    Mines a 2011, but the 2012-2016 one fits the standard subframe, it looks ok with its matching tank but didn’t fit very well with a standard 2011 tank. The front and rear holes line up ok but the middle ones would need a some kind of bracket or holes tapping into the subframe. Couldn’t see if they fit with standard rear light as they’ve not got cut outs.
  9. raphael
    Hi mate,
    Thanks for the effort and pictures, much appreciated.
    As I’m using a full race cover it may well close the gap between the seat and the tank?
    Cheers
