Translogic Quickshifter kit complete and ready to fit to your Honda, Suzuki, Kawasaki or Yamaha 4 cylinder bike manufactured from 2000 and later. This will not work on 2005 or earlier R6 models. Its presently set for a Blade having came off a 2012 bike but as I say can be changed to suit most late big 4 Jap bikes. Comes with the link rod you need for your bike. just PM me and I will confirm this. Translogic shifter systems are regarded as the best around and you can use on any of the big 4 bikes simply by swopping two connectors. I can easily do this for you. This is an ignition based system and you plug it into your coils so you will need some mechanical knowledge. You will probably need to lift the tank and remove the airbox. Its a matter of unbolting and refitting. Its not a hard job but it will take around 1 hour. It comes with the new type DCS shifter which can be used as a push or a pull shifter simply by using the two pairs of plugs, green/blue pair is a push and red/blue is pull. Its not an autoblipper its a quickshifter. The trim dial switch allows you to adjust the sensitivity on the bike while you ride and is useful to you when setting it to suit yourself. This isnt included but can be bought from translogic. Im looking £245 for the kit complete with the necessary link rod specifically made to measure for your bike. Barry 07921 849 076
