Tricky Seat Release Panel
Discussion in 'Maintenance' started by Singh1000RR, Jun 12, 2016.
  1. Singh1000RR
    Singh1000RR Active Member
    hi all, on both my 08 and now 14 plate blade I've always had issues getting the seat release fairing panel back on.
    Getting them off is easy but getting them back on securely is tricky. The tab on the fuel tank cover never latches onto the fairing panel securely leaving a gap in the panels.
    Is there a trick to this I'm missing?
  2. Billalrebhan
    Billalrebhan New Member
    Insert the tab under the tank first then press the panel into its holder, simples;)
  3. 1000rr73
    1000rr73 Active Member
    Yeah, and that panel/tab should be inserted at the front with the panel at something like 45 degrees to the bike to get it to locate fully in.
  4. RRoss
    RRoss Active Member
    I always found one side went in easier than the other,had to angle it right and rotate just to get tab to locate.
    • Downvote Downvote x 1
  5. TW4T50N
    TW4T50N Active Member
    I have the opposite issue: due to a seat cover getting hold of the plastic is a nightmare without flexing it slightly to get a finger behind it.
    Going on has always been easy. Always thread the tab through first then slide it under the seat. Easy :D
  6. Dazzler54
    Dazzler54 Active Member
    Have the panel sticking out at 90 degrees and connect the tab on the tank first, then pivot back into place. Should be easy then...
