Won a two brothers exhaust off eBay. It's arrived today and has no instructions. I understand you have to disconnect the servo cable from under the seat but are there any other tips I should know before o charge in and start pulling parts off a perfectly good bike. What do I need to do about the o2 sensors?
Personally I would have a search on the net and maybe on you tube to get as much info as you can, before I'd start anything. I have just put a Leo Vince on mine and instructions were needed. So have a good look around or maybe someone on here will have some they could e mail to you?
Got it fitted today. Was easy enough after I found some videos on YouTube. Couple of questions. Where can I get the panel to connect to the belly pan, looks a bit spare. Fueling seems a bit lumpy low down, is this normal? Do I need a power commander? What am I supposed to do with the o2 sensor? Cheers
