Tyre Pressure Gauge.
Discussion in 'Maintenance' started by Great Guy, May 6, 2016.
  1. Great Guy
    Great Guy Well-Known Member
    I need to purchase a new one . Are digital the easiest to use. What do you folks use? Thanks.
  2. johnd
    johnd Active Member
    Capture.PNG I use one of these, bought It from maplin.
  3. Great Guy
    Looks good.
  4. Dutch Phil
    Dutch Phil New Member
  5. Great Guy
  6. Slimwilly
    Slimwilly Member
    I buy the old fashioned ones with a dial ,from tool shops,no batterys need
  7. Ian E
    Ian E Active Member
  8. sinewave
  9. Lozzy
    I find this one excellent....not cheap....but you can use it to change tyres too:D
  10. Great Guy
    Would definately have one if it was Shakira holding the tyre.
  11. bradt
    bradt Elite Member
    I definitely want one of those too Lozzy ;)
  12. Remal
    I have a few a snap on digital one that is good. Also a analog one that is calibrated.,
    It may seem daft spending a bit more money on a tyre pressure gauge but it's worth while. especially with bikes where a few PSI can make a big difference
  13. Nigelg79
    Nigelg79 Active Member
  14. Mike07
    Mike07 Active Member
    No point in having a tyre pressure guage that can't tell the pressure correctly. My advice buy a good un.
    Mike.
  15. bonjo
    bonjo Active Member
    I use a Michelin like this which gives me good accuracy (over reads by 0.5psi). It is very small and has a little built in LED ligh But also have a high accuracy mechanical one.
