Tyre pressures
Discussion in 'General 1000RR Discussion' started by ChrisE1722, May 12, 2015.
  1. ChrisE1722
    ChrisE1722 New Member
    I've done a couple of track days now, so I'm looking to change to a better tyre. I've got hold of some 200/55/17, 120/70/17 Pirelli supercorsa's. There the sc2's.
    I'm getting lots of different advice on tyre pressures for the track. So I'm just after some advice off any one out there who uses these tyres.
    I've been told HOT pressures to be 34psi front/26psi rear. Do these sound ok to start with?
    Cheers.
    Chris.
    • Friendly Friendly x 1
  2. scooby
    scooby Elite Member
    not too far off,best thing is to ask the tyre guys at the track,they usually have a board up giving the pressures for each tyre.
  3. Muffking
    26 hot for the rear sounds a bit low as I've been running 29F/26R cold on Racetec's, although I'll be changing back to SC's soon as I've only got a few mm left.
  4. ChrisE1722
    Thanks for advice. I'll try and do a bit more digging.
    Cheers.
