tyre valves
Discussion in 'Maintenance' started by keithg1748, Aug 14, 2016.
  1. keithg1748
    keithg1748 Active Member
    hi has anybody changed the Honda tyre valves cause I find them a nightmare to test air pressure etc ,if you have which ones do you use and any pics ? thanks for your time .
  2. Shutty
    Shutty Well-Known Member
    Couple £ on ebay
    #2 Shutty, Aug 14, 2016
  3. GappySmeg
    GappySmeg Well-Known Member
    I recommend Bridgeport 90degree tyre valves... they look quite good too
  4. keithg1748
    thanks , what size and do these screw on to the original.
  5. keithg1748
    hi thanks do these connect on to the originals ? what size.
  6. Shutty
    Just screw straight on, don't look as good as the Bridgeport, but screw straight to valve, these were just a bit of a cheap trial, will upgrade to something like Bridgeport when I change the tyres
  7. keithg1748
    thanks for that.
  8. raphael
    raphael Elite Member
    The Bridgeport replace are a replacement for standard mate, they come in 2 sizes if I remember correct? 1 for European or 1 for the jap bikes but can't remember the sizes sorry it not helpful
  9. keithg1748
    thanks mate will have a look and maybe change with the tyre.
  10. scooby
    scooby Elite Member
    11.3mm you need for the blade
    8.99 a pair on ebay
  11. TheRamJam
    TheRamJam Well-Known Member
    Interested in a pair of these too.
    Do the 90 degree valves screw into existing valves or do they replace the existing valves entirely (does the tyre have to come off to fit them)
    Cheers
  12. raphael
    They replace the valves mate, so when you get your next pair of tyres
  13. scooby
    scooby Elite Member
    just need to break the bead,no need to full remove
