Tyres Pirelli or Metzler
Discussion in 'Mods, Upgrades, Accessories and Products' started by lockandkey, May 9, 2015.
  1. lockandkey
    lockandkey New Member
    over the weekend I had the opportunity to ride an S100rr and loved the way it effortly turned into a corner. Getting back onto my steed I realised how badly my RR5 turned into corners. So lazy and required alot of effort.
    So after discussions tyres came up a possible reason. Running bridgestone Battalax 023 190/50/17 i was told this was/could be one of the reasons. Having read across the forum it is clear that a 55 will make a difference so I narrowed down my choice to pirelli or Metzler M7 rr. The problem with pirelli there are many possibilities and dont know which would be the correct one. am i after Pirelli Diablo Supercorsa SP, Diablo Ross0, Diablo Rosso Corsa 2, Angel ST or GT.
    I am a Sunday rider, with a trackday booked in June at silverstone (yippeee) and planning on doing a Euro trip (very unlikely, but a man can dream).
    Any ideas on the best/correct choice will be a big help.
  2. ColinBR
    For decent mileage and grip I've found the Metzeller M7RR's to be brilliant.
    Did a tour of Spain and still have plenty left. Best tyre I've ever used and will order another set when done.
  3. Blade048
    Blade048 Active Member
    Pirelli Rosso Corsa is a fantastic tyre for road and track. Came top in Performance Bikes tyre test.
  4. lockandkey
    I guess they will both be fairly equal as far as cornering goes?
  5. Blade048
    I haven't used the Metzelers, but I use the Pirellis on road and track and can say the Rosso Corsas heat up quick and are great in the corners loads of grip although not that great in the wet.
  6. ColinBR
    Metzeller will be a better all round tyre and last longer. As said I can't fault them.
    It's down to what you want to stick on your bike
  7. lockandkey
    I think all rounder would be better, the cornering is my priority and from what I can tell the size matters. how do my current tyres fair against the metzler or perillis?
  8. Si.
    Another set of Metzler M7rr to be fitted for me on Monday. great tyre.
  9. RRoss
    RRoss Active Member
    +1 on the Metzeler,awesome tyre:)
  10. lockandkey
    Metzeler seems to be running away with the vote. where do you buy from ?
  11. RRoss
    RRoss Active Member
    Got mine from local Honda dealer,were cheaper fitted than I could buy online.
  12. lockandkey
    ok. thats interesting, will give them a call. Prices on tyreleader seem pretty good tho.
  13. Mad Matt
    A good set of Dunlop Slicks, there sure to make you go faster, treaded tyres are for little girls;)
    • Funny Funny x 2
  14. Great Guy
    Great Guy Well-Known Member
    Pirelli DRC with a 55 rear.
  15. Cbrjay
    Cbrjay Well-Known Member
    I used to run Corsa 3's great tyre, have you had suspension set up? That will help
  16. sinewave
    No Tyre change will transform your old RR5 in to a sweet steering Beemer!
    PR4's for a road going bike unless U are top of the Fast group.
  17. Andrew Penson
    Andrew Penson Member
    Try TYRE TEC, full range of tyres from most manufactures on their site also the cheapest I've found.
  18. lockandkey
    Tyre Tec coming in at £200 and tyre leader coming in at £196, so tyre leader still ahead of the game. only just. I have had the suspension set up by alpha suspension last year. So thats in place. The beema is a 5 years younger so cant expect the same but small improvements will go a long way. or i could just sell up and buy a panigale 899.lol but that is over complicating matters
  19. Jimbo Vills
    I use pr4's on the road..... If only I was top of the fast group :(
    The new metzeler RR's are incredible on track. K3 on the road would be sticky as shite... Not sure on wear though ;)
    Will def try the new m7 though on the old T, as col really liked them in Spain and wore well ;)
  20. lockandkey
    i don't think there is a bad word out there on the Metzeler, a friend has a blade with Rosso's on so i am going to take that for a quick spin. But Metzeler sounds like it is covering all bases.
