ULEZ Exemption Test
Discussion in 'General 1000RR Discussion' started by Andmorr, Aug 5, 2023.
  1. Andmorr
    Andmorr New Member
    Couple of ULEZ threads but not seen anything about anyone getting a pre-Euro3 bike tested in order to get an exemption certificate.
    I have a ‘96 blade but have seen that ‘97 blades are exempt - leads me to believe (hope) mine will also be exempt if I get it tested and get the certificate.
    Has anyone done this? Test is £175 so obvs only want to go through with it if true / good chance it’ll pass. From my understanding, the ULEZ non-compliant list was basically just done on date of vehicle, rather than actual emissions, so a motorbike should pass.
  2. Broadie
    Broadie Active Member
    Ask honda UK for certificate of conformity on the NOX levels. Then email it to ULEZ.
    Or you can get it tested.
  3. Andmorr
    Andmorr New Member
    I spoke to Honda - they said my bike was too old (and 1996) for a certificate of conformity, so testing it is. Just wondered if anyone else had got tested and whether it was fine
  4. Broadie
    That's disappointing Ducati have done a coc for early monsters on carbs. I'd try someone else @ honda, got to be worth a go.
  5. Broadie
    I've heard of bikes going straight through, but also of someone welding a catalytic converter to a bandit.
  6. warren smart
    warren smart Active Member
  7. bonjo
    bonjo Active Member
    have you used the TFL website which would tell you against your reg number?
