Ok I've got myself the universe blipper from hps I've fitted the quick shifter side and mounted the actuator. The problem Iam having is fitting the cables I've removed and blanked the pair valve to get some space. There looks like a breather pipe that links the head to the airbox can I fit a breather filter to this and blank the air box? This should help with running the cables to the throttle body.
