vaccum pipes
Discussion in 'Mods, Upgrades, Accessories and Products' started by Scottmurray2890, May 2, 2015.
  1. Scottmurray2890
    Scottmurray2890 Active Member
    In process of fitting track fairings at the moment and air tubes and I have removed most of the vaccum hoses. Can anyone tell me what I need to do to blank these off or whether I just leave them open
    Cheers
  2. SimonT
    SimonT New Member
    The advice I received was to put a screw in the last pipe and attach a cable tie. Mine seams to be running ok.
  3. Scottmurray2890
    Cheers Simon
  4. sps170373
    What you can do is take the cap off of the vacuum box thqt sits between the llights and follow the other tube back to the air box and us it to cap off there
  5. sps170373
    What you can do is take the cap off of the vacuum box thar sits between the llights and follow the other tube back to the air box and use it to cap off there
    #5 sps170373, May 3, 2015
  6. Scottmurray2890
    Thanks I'll have a look
