vacuum hoses behind nose cone
Discussion in 'Mods, Upgrades, Accessories and Products' started by DCB, Oct 31, 2015.
  1. DCB
    DCB Active Member
    Guys, i removed my nose cone and lights today, (to fit new lights) but i found vacuum hoses and the likes behind there, anyone know if i can remove these hoses the round cylinder behind the lights and the rest of the gubbins that go with it, if so how would i go about it please?
    Daz
  2. carter
    carter New Member
    This little lot? Bin it all.... unplug the two plugs between the headlights that go to each side. Twist out the diaphragms from the air tubes and with a long screwdriver or similar pop the little metal rods off inside the air tubes that the diaphragms move. While you're in there pop the little springs out or the flaps stay shut... to be on the safe side I got a screwdriver under the flap and got that out to. Get rid of the bottle at the front and the only vacume pipe left goes to the left side of the engine. I shortened that and plugged it with a bolt. The holes left in the air tubes I covered with ducktape and bobs ya uncle.
  3. DCB
    DCB Active Member
    That is the very bastids, sounds easy enough, will give it a try
  4. RepsolSam
    RepsolSam Well-Known Member
    i knew my bike was missing something...lol...
