Valve shim thickness?
Discussion in 'Maintenance' started by Broadie, Jan 10, 2024.
  1. Broadie
    Broadie Active Member
    Hi guys.
    Anyone know what thickness shims are mainly used in the factory?
    Was thinking about shim kits and I'm sure I don't need a kit ranging from 1.2mm to 3.5mm. I'd prefer to buy more of the usable sizes.
    Many thanks.
  2. bonjo
    bonjo Active Member
    If I read the mechanics infor correctly for my RR8 valve clearance @ 16000, the shimes went from 1.83 to 2.04 (mm??)
    In my case, they were all too tight!!
  3. LowSide76
    LowSide76 Active Member
    Don't know if this helps but this was my inspection at 20k
  4. Broadie
    Thanks guys much appreciated.
    Bonjo that confirms my thoughts I shall stock up with 5 of each of the 6 sizes from 1.55mm to 1.85mm.
    Hopefully I'll be able to have the cams out and in the same day. Better when it fresh in my head.
    Many thanks broadie
  5. bonjo
    bonjo Active Member
    you might want to replace the spark plugs while you are at it. I had mine changed at the 16k valve service to save some money
