Gents, Apologies if this has been asked before ( I did search) , has anyone here used the Vario footrests available from M&P? I find the standard rests a tad high on a long ride, these look like I can perhaps adjust to fit me a bit better. Thanks Mike
Had these on my Ducati to kick the pegs backwards, but being a Ducati the allen key pivot was always vibrating loose, even with loctite. Gilles do these.
I've got a set of these and they do work well, only downside is that the rear brake pedal is difficult to reach at first as you need to twist your toe in to reach other than that there fine, I'm looking at getting a spare pedal to modify with a wider rest View attachment 18278
Not the best pic mike will take another for you when I get home, have seen similar on ebay cheaper than m&p will find the link for you
