Ventura luggage system rr5
Discussion in 'Mods, Upgrades, Accessories and Products' started by nickcbr, Mar 8, 2012.
  1. nickcbr
    nickcbr Active Member
    Hi,
    Does anyone use the Ventura luggage system on an rr5 blade?? If so could you do me a favour and measure the distance between the two prongs that stick up for you to attach the different fixings (rack/handle etc) to please?? Or measure the width of the grab rail please??
    I ask as I bought a bargain Ventura sports rack off the bay 20 quid and it looks way too wide for the blade. I haven't got the L brackets yet so have no way of telling
    Thanks for any help
    Nick
  2. fireblade
    fireblade Active Member
    the part no for the pack rack is PF14/B and the part no for the grab handle is GH14/16/B and sports rack is SR14/B
    if this help. I will check the distance on mine and post that for you tomorrow
  3. nickcbr
    Cheers mate
  4. fireblade
    The distance between the two prongs is 32cm
  5. fireblade
    Heres the best i can do with the fitting instructions for the L brackets
    1 remove seats and rear body
    2 Remove and retain the plastic heat shield/cover from the rider footpeg to the pillion footpeg castingnon the right hand side
    3 Remove and retain the allenhead bolts from the rear subframe to pillion footpeg casting. Replace the forward bolts after placing the M8 x 22 x 3.0 flat washers between the casting and the frame. leave loose
    4 Remove the two downward pointing rear luggage securing hooks, the L-Bracket rear mounts secure at these points using the original bolts
    5 Fit the 18 x 40mm piece of foam tape supplied to the outside of the forward flat mount on the right hand L-Bracket to prevent marking the rear brake master cylinder.
    6 the forward L-Bracket flat mounts fit between the rear subframe and the pillion footpeg mount castings at the rearmost holes. Secure using the original bolts. Leave loose.
    7 Fit pack-rack or sport-rack into the L-Brackets, ensure the rack is level and tighten the mounting bolts.
    8 Refit body and seats
    I have the system fitted to a RR4 which is the same as the RR5. I love the system when riding on your own the bag sits on the seat keeping the watt forward then when you wont to have a passenger you can turn the bag around which you can't with a tail pack
