I bought a Ventura luggage system just before I got my blade - found it online for pretty cheap. I was told it would fit but unfortunately it's for the 04-06 model - and mine is a 07. So I have the l brackets for the 04-06 model for sales if anyone wants them - but also I'm looking for a set for the RR7 bike - just in case anyone has a set? Thanks
Models are split as 04-05 and 06-07...... And as far as the tail section I think those two models are identical (I could be wrong, please correct me if I am).
From the site: http://www.ventura-bike.co.uk/products/bikepacksystem.aspx - it says the 04/05 is the H121, but the 06/07 is the H125. This is mine: It's a H121 http://imgur.com/gc03jV4 http://imgur.com/WoqTDaZ I was told the back of the 04/05 is different to the 06/07. I'm not sure how it fits but maybe I should have a look just in case - or are they totally different?
Where abouts are you Colly? I have both bikes and can't see much difference between the two other than the fact that the RR5 has more brackets attached, so I can't see the RR6/7 version being difficult to adapt.
Too far to see mine then How about you start fitting it and post pictures, then I'll check my bikes and see what's different.
I just realised I only have the rails and I dont have any of the screws etc. Are they standard or do I have to go to Ventura for this?
I don't have one, so hard to comment, but I'd be tempted just to offer them up and see if it uses existing mounting points that already have bolts to reuse.
They fit to existing mount points which I can check for you on mine (RR6) and there are 2 washers which space the rear to fit the back bracket/handgrip. I'll check on thickness and where they fit if you want ??
