Voltage Regulator advice
Discussion in 'Maintenance' started by SimonRR, Oct 26, 2014.
  1. SimonRR
    SimonRR God Like
    #1 SimonRR, Oct 26, 2014
  2. Daznorthwest
    Daznorthwest Elite Member
    I'm not right clued up on this so I think I'd go genuine.. Couldn't be ased waiting 2 weeks for Chinese post just to have it fail again then buy a genuine one
  3. Iain
    Iain Active Member
    What bike ? 04 onwards is more likely to be the stator, before that the RR!
  4. SimonRR
    SimonRR God Like
    2005 but done all the stator checks for resistance and voltage and its putting out loads of volts so that should be fine :)
    Done the volt meter tests on regulator and it fails those tests
  5. Iain
    Iain Active Member
    How many miles ? This could be the first example of a RR going on an 04 onwards blade I have heard of! Has it had the new stator?
  6. SimonRR
    SimonRR God Like
    Not sure about new stator, bike only done 18500, 11500 with me
    All tests point to RR though, and there is always a first time for anything lol ;)
  7. dave d
    dave d Elite Member
  8. SimonRR
    SimonRR God Like
    Not really sure on used? Could be about to go bad it's self ;)
    Will be new from Honda or new from China I reckon, might try the China one as got to much on for bike riding for a while Amway, and can then give a review of how good/bad Chinese ones are lol ;)
    Time will tell :)
  9. Barstewardsquad
  10. martinowen
    I'm sure you checked already but it's not the battery is it? Only saying as they tend to go when the weather gets colder.
  11. SimonRR
    SimonRR God Like
    battery is fine Martin :)
    RR has failed the voltmeter tests, rest of charging system passed those, so thinking it must be the RR?
    Bike runs fine but battery won't charge, when you check battery (after Full charge) the voltage at the terminals doesn't change while increasing the revs, so no charging getting to battery
  12. martinowen
    Sorry mate wasn't calling you stupid :D
  13. SimonRR
    SimonRR God Like
    Lol didn't think you were mate :) were you? Lol ;)
    #13 SimonRR, Oct 27, 2014
  14. Mike07
    Mike07 Active Member
    Are you completely happy with the testing you have done? as to your question would I use Chinese electronics, Yes I would. RR is a simple thing.
    Mike.
  15. SimonRR
    SimonRR God Like
  16. Mike07
    Seems really comprehensive, I can't help past what you have done. Looks like a new RR. Re the Chinese RR It's a hell of a lot cheaper, they may use components that are less accurate in there construction and the tolerances of output etc may not be as accurate. but for what it's doing that isn't important, as long as the battery is getting voltage near enough it's fine. Just because they are not as precise doesn't mean the longevity is compromised, as I said it's basic tec.
    Good Luck,
    Mike.
  17. SimonRR
    SimonRR God Like
    I have ordered that Chinese one now, just because its so cheap and will let you know if I blow up or anything lol ;)
    will be interesting to see if:
    1. it works properly?
    2. it last long enough for the price?
    3. it doesn't cause me any serious problems?
    time will tell :D
    will keep you all informed, just in case anyone else ever needs one?
    that .pdf file is great too for anyone with the same Charging problem :)
  18. morpheus20170
    morpheus20170 Active Member
    Did you not say you tried the voltage over the battery terminals with a fully charged battery as if you did and you got no more voltage from the battery with an increase in revs this says stator to me.
    04-05 are crap for burning out stators and need the matching pair from Honda or David Silver.
    Good Luck
  19. Muffking
    Don't worry, if all else fails I'll have a complete donor bike on Tuesday that can be used to track the fault down ;)
  20. SimonRR
    SimonRR God Like
    Well new RR in the post now so will see if that cures it or not ;)
    If that don't work then I will take the stator out and get it fixed, cheaper than buying new?
    Someone put a link on here for a company that rewinds stators
    But stator is putting out loads of volts and the resistance test also shows no problems which is why I think it RR
