Does anyone have a soft copy of the Translogic quick shifter manual they could share with me? I've just bought a 2012 blade with one on and I want to read up on it. In particular I need to switch it to a new sensor in race shift pattern. I've had a look on their website but to download you need the product serial number and I can't check mine because the bike is on its way to Spain CheersCheers Ian
The translogic needs either a push or pull shifter. It has no idea what road or race shift is. The shifter is pretty much identical to the dynojet one (dynojet make them for translogic). So I dont see what you need the manual for in that regard. Its very easy to determine are you pushing or pulling. Simply simulate a shift 1 - 2 - 3 and it the rod pushes its a push and if it pulls, its a pull.
