Gutted Just brought a warrior headstock stand and It does not fit my 16 blade, Pin to small And does not fit my boys 924, brake pipe in the way Pi##ed off to say the least Any ideas
You need a 23mm-ish pin for the later blade. I bought the 24mm from sportsbikeshop and took a bit off on the grinder which took all of two minutes. Can’t say anything about the earlier blade as I haven’t seen one under the headstock.
As above. I would imagine that it just needs the right size pin buying or making up. We had the same issue at Donny when trying to lift a Ducati. Ended up turning a 24mm socket upside down over the pin to get it to fit the headstock.
