Waterless Coolant - (Discussion)
Discussion in 'Mods, Upgrades, Accessories and Products' started by nigelrb, May 8, 2018.
  1. nigelrb
  2. TheMickster
    TheMickster Active Member
  3. tuktuk
    tuktuk Elite Member
    Think that guy is running a test with it in 9ne of his bikes to prove why its dog cac.
  4. raphael
    raphael Elite Member
    I think there was a discussion on here a few years ago? I know a few on here who are using it, one being lamb chop rides on YouTube. I was thinking about using it in a few weeks/ next service so keen to see the out come
  5. nigelrb
    Good enough for me, ta. I'll stick with Honda or Castrol.
    On further reading of the Evans docs, the system has to be totally cleaned and prepped for the product. An hour for a tech or two hours for a novice.
  6. Slick
    Slick Elite Member
    I struck this off the list a while back, its main advantage is that it has as higher BP and thus puts less pressure on your cooling system.
    My take is if your cooling is running at higher temps then you have another problem, inefficient rad wrong afr etc.
    The best scizzle at getting rid of heat is water, the only problems are it freezes at 0c and corrodes the feck of of ferrous materials hence the additives. I just use castrol gp, use it on track days, sub zero and sitting in stationary in 30+c no problem.
  7. TheMickster
    I use Silkolene Mag Cool in mine.
  8. nigelrb
    Cheers. Just read some reviews. Sounds good. No frigging around with pre-conditioners and cleansers.
  9. BlackDevil
    BlackDevil God Like
    Using this since 2011 in combination with the Samco Silicone hoses.
    Once done properly, you can forget about your cooling system.
    Everything else is just the second best.
  10. Jez
    Jez Senior Member
    I am new to coolants, I knew some are better than others but are some better at conducting than others.As an engineer we used to quench things in water to harden them this cooled them instantly, other things we put in oil but after quenching it was still glowing red..so some fluids will be better at conducting than others
  11. BlackDevil
    BlackDevil God Like
